The cricket thread
1100101103105106266
  • crunchmancrunchman Frets: 11462
    Unless Aus now blow England out in a session or 2!
    9 for 2.  Entirely possible.  Likely even.
  • RandallFlaggRandallFlagg Frets: 13946
    edited August 2019
    Root for a Duck...9-2
    FFS
  • scrumhalfscrumhalf Frets: 11319
    Oh for fuck's sake, this is embarrassing.
  • HeartfeltdawnHeartfeltdawn Frets: 22204
    You can win one day games revolving around one person with the bat and one person with the ball. That doesn't work at Test level. Even with Warne at close to his absolute best in 2005, the Australians didn't win the Ashes because they didn't have a bowling unit like ours. For the first time in ages, we have a bowling line up that looks right for these conditions.
    Look at what happens when you have a spinner who exerts some control. Look at what happens when Broad works over the winter on a new run and pitching the ball further up and compare that to the fucking disaster that was the 'Broad as enforcer' period. Let the new kid on the block be the pace enforcer. Let Woakes do this thing. And look what happens when your captain actually uses bowlers at the right time and applies some decent tactics.
    Whatever happens in this Test, if Anderson is fit for the next one I wouldn't bring him back.
    At this rate I'd bring the Burnley Lara back for his batting
    S'funny, Mrs HFD was asking if I'd be available to install a new oven and induction hob half an hour ago and didn't quite understand when I said 'Not ruddy likely, I'm off to Lords'.
    Might just have to get my screwdrivers out after all.
  • earwighoneyearwighoney Frets: 3497
    FFS
    Captain's knock....
  • StuckfastStuckfast Frets: 2418
    Oooof, that was a snorter that got Burns.
    It's going to be a nail-biting day's play tomorrow. Forecast is for showers.
    Draw is most likely but a batting collapse can't be ruled out from either team to get a result. It's been a gritty and good match so far.
    You probably want England getting bowled out about 10 minutes after lunch.  Would make for an interesting afternoon.
    Currently watching the live stream of Northants vs Worcs. Moeen Ali looks shakey but he's still there at 15-4.
    Play starts at 12:10, 88 overs.
    All four results are possible, with varying likelihoods.
    Smith not fielding, Aussies hsve applied for a concussion substitute.
    A like for like player?  =)
    I think it has to be. It's Labuschagne (sp?)
    Day 5 183-5 with a lead of 191: England playing much better in this match, aggressively trying to push the score along after lunch and then put Aus in to bat and try and skittle them.
    Whatever the result, this is what I want to see from England. I'll take Eng 1-1 Aus or Eng 0-1 Aus going to Headingley on Thursday
    Need to declare soon.  If England declared now, the Aussies would require well over 3 an over*, on a pitch with lots of rough and no fielding restrictions.
    * If they get all the overs in that is.  Given that they will almost certainly behind the over rate, the Aussies are probably out of it already in terms of winning.
    The Lords pitch is a very weird one. Yesterday, it seemed very lively and gave the bowlers a fair amount.  Today the pitch doesn't seem to be giving the bowlers much, be it the spinner or the quicks.
    It might seem a cynical decision, but I think Root should avoiding declaring as late as possible.  Wickets seem unlikely now, but the more time the Australian bowlers spend bowling now the more fatigued they might be for the next test match in a few days time.
    edited August 2019
    Need to declare now.  It would already be well over 4 an over (if they get all the overs in, which is unlikely).
    Leach can bowl into the rough outside leg stump if necessary (not that it would be).
    The best way to bowl the Aussies out is to give them an outside chance of a win.  If you bat them out of it, they will leave everything they can, and bat out for a draw.  You want them trying to put bat to ball.
    The Aussies hold the Ashes, and we are one down already, so we have to be aggressive.
