I just measured up what my standard straight plastic one was (that I’d already filed and lowered) and found one to roughly match. This is what I bought: Bone Acoustic Guitar Saddle Compensated 74mm wide 8mm,9mm or 10mm high (8mm High) https://www.amazon.co.uk/dp/B07DRVDZ3R/ref=cm_sw_r_cp_api_i_yEQFDbFWYYABC
Looks a little rough maybe but sounds much better so far. Maybe I’ll try and polish it up next time I do a string change.
Might take it to the shop so they can remedy anything I've bodged regarding the saddle/bridge, and give it a polish and service. Other than that, there's nothing wrong with the guitar at all.
You could just order a new saddle and start from the beginning yourself, could be a nice project!
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Blisstime 6pcs Ebony Guitar Pins Inlaid Abalone Dot Acoustic Guitar Replacement Parts https://www.amazon.co.uk/dp/B014FA1ZDG/ref=cm_sw_r_cp_api_i_TfMHDbZJJWYJ7
Pretty cheap but but they do the job nicely.
It brightened it up a bit too.
I think the combination of plastic nut and bone saddle is a good choice for this guitar, I think that perhaps a bone nut may brighten it up a bit too much.
