I have just been watching some very good youtube videos on this very subject.
some of it depends on the type of wood ie some woods need grain filling first. and different types of finish require different techniques
but if you want a top finish you can not be lazy and you definitely can not rush it.
what type of wood and finish are you using?
Ive had some cracking finishes straight out of the can, only to be disappointed when I see swirl marks from the sander or not using fine enough grit.......then you have to start all over again to remove the finish and paint it again (or shove it in the loft and sulk!)
• Youtube - https://www.youtube.com/@Goldeneraguitars
