Mesa Boogie Studio 22 - £450 ono
Selling my other 'practice' amp is it doesn't really get used these days due to lifestyle work etc etc...
Mesa Boogie Studio 22, with EQ. Great sounding and LOUD 22w amp.
Pics here:
https://flic.kr/s/aHsmHFUbR4Pickup from SE London, more than welcome to try before buy.
Comes with a protective cover too that I forgot to take a pic of.
Does it have a pedal switch for the reverb? What's the reverb like? Any service history? Can you run them at half the power? Original speaker?
Yeah I was just reading it was a nirvana esque piece of kit, I've had a little look at the schematic of it which looks interesting, 390 volts across the EL84's is borderline insanity, how many tubes have you gone through? I quite like it when amps are designed to work on the limits of physics though...
Rob.
I've not ever heard a bad word against them actually....
JJs seem to mostly be OK with it. I wouldn't normally use Sovteks.
That's within spec for KT88s - and actually for EL34s too - 800V. I hope you haven't biased it any hotter than you would with the 6CA7s - these are very unusually-designed amps that run on the edge of Class B and you can't bias them as you would a normal Class AB amp.
Their power valves are the most reliable new-production ones in my experience. I strongly dislike the sound of their preamp valves though, and I've seen enough 12AX7 failures in cathode-follower positions to think that they have a similar problem to Russian ones, if not so bad - inadequate cathode-to-filament insulation.
It does sing though, brilliant for bass and guitar. Really pleased with that. And its very very loud. My favourite amp.
I have its bigger brother:
