I fancy getting a new strat but I’m tight on cash. The amount of partscasters around got me thinking whether I should go down that route or not. I’m of the snobbish belief that custom shop and luthier built stuff is ALWAYS superior and buying a mismatch of parts will just be crap.
I was turned to the idea when I found out today that SVL buys in his bodies and necks after liking his stuff for a long time and wanting to buy one. Not that I’m downplaying the quality of his stuff in any sense.
In essence could I buy good quality parts that are finished well and get it properly set up by feline or alike and be happy.
I appreciate this is a matter of personal taste and circumstance but I’d appreciate people’s views and opinions and even a point in the right direction for good quality parts.
The only thing with a parts guitar is that you can never be certain on the end result until you've paid your money and taken your chances.
A DIY guitar built to good specs, well assembled & set up can easily match the best (possible heresy, but I'll stand by that).
But... not as an investment or speculation as it should really be described.
But sod that, if you can build it & love it then go for it.
After all, it's all about you
My personal view is that a partscaster eventually gives you a better guitar, which is more closely fitted to what you want than an off the shelf model. You also learn a lot by building one (which inevitably leads to another).
However it is not a cheap option. Buying individual components means that you don’t get the bulk purchase prices which manufacturers get. You also have to learn, with the cost of re-working if you get something wrong.
If you want cheap then buy a reasonable quality budget guitar, such as a Harley Benton from Thomann, or buy second hand.
I've put a bunch of partsacasters together over the years and didn't want an amateur finish on this one so left it with Jonathan and as usual he does not disappoint.
Re SVL - there is no glory in making your own bodies and necks. Many smaller builds have their core stock outsourced to someone who does it better than they can. That allows them to concentrate on other aspects of their business. We buy our bodies and necks in because of these points
• no space for tooling
• no space for wood stock
• no access to good timber in quantity
• no time to manufacture
The list goes on...
• Youtube - https://www.youtube.com/@Goldeneraguitars
Best value option is buy a Partscaster that someone else has put together – there are usually loads on eBay often with top quality hardware and pickups. A lot cheaper than buying the parts separately anyway.
I put a guitar together using Fender custom shop neck / body and premium pickups etc. and it was nearly impossible to sell.
Whilst I concede that the outcome is only as good as the components you use- buy the best you can. I disagree with the assessment that you have to spend lots of money to get something good.
If you're patient it's possible to gather the parts you need via the Classifieds/Facebook/eBay/Gumtree. Everything on all my guitars is from a "known brand or maker" & yet none of them cost me more than I wanted to spend.
Money can also be saved if you're handy with a soldering iron and/or spray can. I LIKE to feel the wood *fnar fnar* in my guitars, so all are oil finished. Which is cheap, easy & relatively doable in a flat with kids running around constantly.
I agree that you should be prepared to spend on a final set up from a good tech, but it's not always essential. Build it & see what you think- if your neck is second hand then the nut MIGHT have been cut properly etc. That said, a professional setup can be the difference in feel between a good Partscaster & a great guitar.
The biggest downside are that as others have said
1. There's no money in reselling the guitar- even if you've bought the components second hand. It's often more economical to break the guitar up & sell it in pieces.
2. It's time consuming & can be messy- especially if you're doing some finishing.
3. They can be hard to sell. You build something to your preferences so it's hard to sell unless someone else has those specs in mind.
4. It's addictive- you build one because you "need" an Esquire Tele, then you "need" a HH PAF Shiflett Tele Deluxe, next you see Guitarbuild have a sale on & there's a Walnut Telemaster body at a good price... Slippery slope.
The whole guitar ended up costing about £250 and I'm really pleased with it. And because it's all USA Fender bits it all just fitted together perfectly with no issues. I don't actually know what brand the body is but it's quite heavy compared to a regular Tele body, made of ash I think but spray canned white now
Any second hand squire could be a steal. Upgrade as you go.
Injured Veteran and head injury survivor. Bouts of grumpy behavior and brutal humor are to be expected.
Red meat and functional mushrooms.
Persistent and inconsistent guitar player.
A lefty, hence a fog of permanent frustration
Not enough guitars, pedals, and cricket bats.
USA Deluxe Strat - Martyn Booth Special - Epi LP Custom
FX Plex - Cornell Romany
How tight on cash? Might help us understand what your options are. As stated above parts guitars can often spiral in costs.
Who is SVL?
