Hi all,
Possibly not the forum for this, but thought I'd give it a go. I recently subscribed to IPVanish and have installed it on my Raspberry Pi. However, I have Virgin Fibre with a SuperHub 3 and am finding that the bandwidth is being throttled significantly.
Having had a read around, the only real answer seems to be to put the Virgin router into modem mode and add a new router with VPN installed after it. I could change provider, but don't fancy the other options and easily having all of our devices connect via VPN without the need for configuration of each device appeals.
Stability, relative ease of use and good WiFi distribution are all important and I trying not to pay less than I need to (though don't want to spring for an enterprise unit for domestic use).
Thanks to anyone with advice to share!
I stopped using IPVanish and now use Unlocator.
It is much more efficient and we have no problems getting iPlayer outside the UK (our main use for it).
Think carefully if installing VPN on the router will work for you.
There are several instances where doing so will be less convenient than making it per device.
Some services might not work as expected.
My wife's work computer wouldn't connect at all because it had its own VPN trying to route through another VPN.
In our Swiss house we couldn't use the local IP-based TV because it thought it was outside Switzerland.
If you have Virgin media and want to use catch up TV it might not work because again the box will think it is outside the region.
My advice would be to use a better VPN or Smart DNS rather than putting VPN on the router.
You'll also get a lot of recommendations for TP-Link as they're ubiquitous, and they're "OK" but not top of my personal list, he said diplomatically.
However, if you're going to set the VPN up on the router itself, rather than using a 'soft' VPN on your device, you'd be well advised to go for one that comes with setup info and known compatibility with your VPN service provider, as it can save a whole world of pain.
As @octatonic says above, personally unless you specifically need to put the whole LAN behind a single VPN, I'd be looking at using a software client on the endpoint, rather than doing it on the router.
As a matter of general privacy, the idea of having all devices connected to my network being able to access the internet anonymously appeals, hence the thought of a VPN-level router. However, it sounds like that might not be as straightforward as I thought. Though I'd imagined a lot of the regional issues outlined above could be circumnavigated by connecting to a UK-based server?
We use the Pi for everything from internet radio to Spotify, iPlayer and YouTube to Mame and some use of Exodus and the like. The main aim of whatever comes next is to stop the Virgin router throttling the bandwidth of the Raspberry Pi while it has a VPN running, so any advice on the best way to do that gratefully received.
I use a Fritzbox 7490.
It is excellent.
It also acts as a DECT basestation, media server and will even do ISDN if you need it.
If you don't need this features then maybe not.
If your VPN provider just lets you set up a standard IPSec or similar tunnel, then most any half-decent VPN router will do it (although some will be harder to get working than others).
If you actually need to install a specific package, rather than just configure an industry-standard set of options, then you're going to need something that lets you get a bit more low-down and dirty (e.g. a box running pfsense, or a home-rolled solution).
