FS/FT: 1 piece ash HH Tele body
These were meant for a project that I am never(?) going to get done.
The neck is from a MIM Ed o'Brien Strat. The back has been lightly sanded. Other than that it is like new - £150 ppg SOLD
The body was from booboo, so a guitarbuild reject. There was a slight split where the controls were drilled which I have reinforced with a thin piece of mahogany. It has a strat neck pocket but will take either Strat or Tele neck. It was a 3 bolt but has been converted to a 4 bolt and a couple of holes have been drilled for a Bigsby and a neck plate. 1.9kg in weight, this 1 piece was the most expensive body on offer at the time and would no doubt cost you double from GB. With a little TLC could make a great build. £90 ppg
https://www.boobooguitars.co.uk/collections/guitar-bodies/products/sc-body-512695
