Some support (that also gets drilled into....don't use your fingers) on the inner surface of the "Can" will prevent the burrs pretty well, probably enough that you will be able to de-burr them with some sand paper.
That's the Enginering theory anyway, but seeing as I'm assuming it's a curved surface, you'll have to be a bit inventive in how you do it.
Edit: My point is.........Rigidity is the key aspect in achieving your very lightly burred hole
They don't grab like a normal bit.
https://www.ikea.com/gb/en/p/ordning-kitchen-utensil-rack-stainless-steel-30131716/
That would be the most efficient method. It will still leave burred edges. (Mostly on the inner surface of the lampshade.)
Tricky. Not even a plasma cutter is likely to manage that.
