Excellent condition, TS9 modded to original TS808 specs and improved. Info from Keeley:
http://i749.photobucket.com/albums/xx136/pickergra/Mobile%20Uploads/IMAG0107_zps301562dc.jpg
Edit: not true bypass version as originally stated, however pedal has improved bypass sound when not in use.
I assumed it was, I'm sure that's what I bought but could be wrong. Anyone know if there is an easy way to find out - Are the true bypass ones labelled differently at all? I may have to check with Keeley...
Yes, looks like it's not the true bypass one. Bypass just improved "New Improvements to the Bypass circuitry! Yes, we make it sound better even when it's off!"
Thanks for pointing that out and the info Viz and Fretfinder.
