boss ds-1 repair
phil_bphil_b Frets: 2010
edited January 2020 in Making & Modding
I just bought this on ebay as a faulty pedal. The description says the distortion knob is stuck in one position and can not be adjusted.
I am hoping a new pot will fix it. As I wait for it to arrive can anyone tell me what type of pot I need. If I can order one whilst waiting for the pedal it would speed things up a lot.
  • ICBMICBM Frets: 72445
    The pot is 100K linear, but if I remember correctly there are different versions used depending on which series the pedal is - the early knobs have a set screw (needing a solid-shaft pot) and later ones need a split/splined pot.
    I would hold off until you have the pedal, anyway - it’s not unlikely you can free it with a bit of care and some WD-40, in which case you don’t need a new pot...
    0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • phil_bphil_b Frets: 2010
    thanks for the advice. Patience is not my strong point but you are right it will be better to wait
  • SteveRobinsonSteveRobinson Frets: 7039
    Well you couldn't turn that down [Badum tish!]
    8reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • randellarandella Frets: 4185
    Fiver says you fix the pot and end up setting it exactly where the old one was ;)
    3reaction image LOL 0reaction image Wow! 3reaction image Wisdom
    lol... wis
    well the pedal arrived.
    the pots seem to turn fine so I plugged it in and the level and tone pots function correctly. the pedal has zero distortion and turning the dist pot has no affect. I opened it up and the pot measured out ok and the connection are fine.
    then checking the board for any obvious damage I noticed capacitor C8 was missing. it has been snapped of and only the legs are left soldered to the board. the body of the capacitor was not in the pedal so this shows the pedal has been opened up before. This may be the fault or it could be damage after someone was poking around in there.
    a quick google shows C* should be a 0.47uF cap and is part of the distortion control circuit so there is still some hope there that this could be the only fault.
    Yes, if C8 is missing that will turn it into a clean boost (if there is even any boost, it will give the second IC stage very close to unity gain) pedal... sounds like someone has been fiddling without knowing what they were doing.
    There goes my theory then ;)
    At least the cap will only cost you pennies to find out.  I wonder what they were up to?
  • LastMantraLastMantra Frets: 3822
    Good buy! Assuming it was cheap of course.
    not really. I over paid to be honest but I do like tinkering with stuff
    well after having to wait a while for the correct value capacitor to arrive I soldered on into the gap on the board.
    and I got luck and the pedal now seem to be working fine. happy with that
    It still a mystery to me how a circuit board can loose a capacitor however
