And the deluded EBay seller of the day award goes to...
  • ModellistaModellista Frets: 2044
    That chunk out of the top of the fretboard is unforgivable. Happened when removing the old nut, apparently. And then he just threw the bit away. Clot.
  • guitars4youguitars4you Frets: 14512
    edited January 2020 tFB Trader
    Wonder what makes this Tele unique sounding, yet still retains the typical Tele twang
  • KittyfriskKittyfrisk Frets: 19165
    If it's from Barnsley it's probably seen more than it's fair share of hand to hand combat.
  • ICBMICBM Frets: 72796
    The body appears to be alder not ash, which means it's a stripped solid colour guitar and not an original natural.
    Not worth a grand in that state, let alone three.
  • LitterickLitterick Frets: 662
    It suits the armchair and the curtain.
  • TeleMasterTeleMaster Frets: 10361
    It's a refin.
    It's a refin.
    It may technically not be refinished, but stripped to the clear undercoat which they put on the bodies under the coloured paint - it tends to look like that. Either way, it’s not the original finish.
    There’s also a hole right through the headstock where someone has used a too-long screw for one of the original machineheads, before they were replaced... it’s a complete mess, basically.
  • im thinking of offering £150?
