The further bad news is... pause, I'll just check an email with KMMK....
"Hi Chris,>> >>>> >>>>>> The SP400 won't work on the ES5 and ES8 from boss. The SPS4>> will."
Yeah, so sadly boss won't accommodate the square and KMMK does not do a TRS SPS4!
A potential solution, however, and it may also be an unsightly/impractical one. Would be to use a right angle TRS Neutrik / Rean for the ES5 end.
One of these would fit between your other plugs however if using a flat board, then the cable exiting the barrel/boot and the bulk of the assembly itself will be pointing vertically upwards, so like a little flag pole behind the ES5 display I think? Of course if you are using something like an angled Pedaltrain, then there could be enough play there to have the right angle jack sit under the ES5 toward the floor.
I'm assuming you are using this switching your amplifier? Again I will be glad to help and have both the Neutrik TRS and Rean in stock. You'll, of course, need to consider how everything will hook up. My gut here is saying you maybe have a TRS patch bay on your board and need the ES5 to meet that to then go onto the amp? I could be completely wrong!
and in addition..... I have owned and wired up my own Boss MS-3 before. I know what you're going through!!
My pleasure man, if it wasn't for being able to talk to anyone or everyone I wouldn't be able to do what I do! Are you enjoying the Revival Drive? I haven't yet had a chance to plug into any Origin Effects stuff, I'll need to escape the countryside soon!
Too many choice to decide!
Also, one final question, what is the cable "footwear"? Is it the little coloured "crown"?
Thanks!
