Squier JV P-Bass resurrection
MattNovakMattNovak Frets: 907
edited March 2020 in Making & Modding
Not strictly making or modding, but I wasn't sure where else to put it... I recently bought a project bass from this 'ere parish, sold by @prismrock2003 (who is a gentleman to deal with btw).
I'm restoring it as far as possible back to factory specs - as can be seen, it's some way from those at present:
www.theflyingacesband.com
  • MattNovakMattNovak Frets: 907
    The good bits:
    • The paint stripping job, although crude, didn't wreck the body contours.
    • It's an '82
    • The original scratchplate hasn't been altered
    • The tuners, strap buttons etc are original
    • The factory finish is still on the neck
    • No additional routing
    The bad bits:
    • Factory sunburst finished stripped (obviously)
    • Frets removed and slots filled with 'stuff'
    • Pots seized and corroded beyond salvage
    • Original pickup missing
    The plan:
    • clean fret slots out and re-fret with correct wire
    • refinish body in nitro - examples from this year were only available in white, black, fiesta red and sunburst - I will go for black
    • restore the electrics, using as many of the original bits as possible (even down to the capacitor and locking rings!)
    • The bass came with a SD SPB-1, which I'm told is a great pickup - I have no opinion on the originals so will likely go with what I have
    Anyway, that's where we are. I'll update the thread as things progress.
    Rock on,
    Matt
  • FunkfingersFunkfingers Frets: 14572
    Seymour Duncan SPB-1 is, indeed, an excellent pickup. Their Antiquity models are even better ... at a price.
    The stock pickups on the JV Stratocasters were Made In USA. I cannot recall whether the bass pickups were or not.
    For what it is worth, I have a Fender AVRI '58 Raised A poles pickup in a Squier Silver Series P Bass. This has similar basswood/maple/rosewood construction to your JV. With flatwound strings, it sounds pretty convincing. (I have a Fender AVRI '63 for comparison purposes.)
    Good to hear, @Funkfingers - thanks. The SD pickup covers don't quite squeeze through the pickguard cutouts, I could take some sandpaper to them or buy a new pair of covers....
    Whoever stripped it gave up when they got to between the cutaways! Forgot to mention the JV neck plate is present and correct:
  • WezVWezV Frets: 16777
    those fret slots may not look pretty, but they could have been a hell of a lot worse.   Imagine big chips at every fret instead like most wood filler fretlesses - including the one I did when I was 16
    the board will come up fine with a bit of work
    They can tricky with either abrasive or a heat gun and scraper. Scorch marks are best disguised under an opaque colour. Dupont/Ducco "custom color" car paints would look the part but the poly needs to come off before any nitro-cellulose goes on.
    Perfect kind of project.  Looks good!
    The frets seem to have been removed relatively carefully - which is a plus. There's a few small chips here and there towards the upper register but they've been there so long they're hardly noticeable - at least not as much as 'fresh'.
    Needs a final dress and polish, but the refret was drama free:
    Yeah, after having a closer look they'd used a heat gun and not cleaned the scorch marks off. I've been over the body to prep it for paint and shot a white primer just now...
  • paulnb57paulnb57 Frets: 3072
    Nice project, great progress! Good to see an instrument being brought back to life...
    edited March 2020
    The paint is on - I purposefully didn't fill in the knocks, the neck has its original finish and is roadworn to say the least, so a pristine body would have looked out of place. 'Sympathetic restoration' is the poncy term for it I beleive.
    Need to further harden, and then buff and polish but it's looking ok:
    Excellent!
  • ICBMICBM Frets: 72600
    That's probably because the guard has shrunk slightly - even the MIJ ones do. It's not a sin to very carefully enlarge the holes, as long as you make it neat. You will, obviously :) - I've seen a few horrors that looked like they were done with an angle grinder though...
    I would fit a USA Switchcraft jack too, even if the original will clean up well enough to work - they're just not very good quality.
    @ICBM - you're right, I hadn't noticed the guard had shrunk until I noticed it wasn't laying flat on the table. I have heard stories of people taking guards off for a while and then not being able to fit them back on, can they shrink that much?
    Anyhoo - I got it finished and screwed back together over the weekend. I added what I hope is some age commensurate wear as fresh paint over a slightly battered body looked 'off'. Nothing extreme, and I'm glad I used a white primer as it contrasts nicely:
  • danishbacondanishbacon Frets: 2699
    Sweet bass!
    The original 60s ones can, yes. The more modern ones not so much, but it may only be a matter of time.
    That’s a very nice job :).
  • sixstringsuppliessixstringsupplies Frets: 429
    That looks superb - I love tortoise pickguard against black.
    Just for my curiosity - how did you get on with sourcing original pots?
    For Modders, Makers, Players
    https://sixstringsupplies.co.uk/
    Our YouTube Channel for handy "How-To" Wiring Tutorials
    Thanks ICBM and sixstringsupplies
    I bought some fresh Alpha pots, but unexpectedly I was able to salvage the originals. They were seized when I got the bass, and would only turn with pliers - but I managed to free them off and, whilst there's more resistance in turning than normal, work fine. It means the only new soldering to the original electrics was the pickup. I was surprised too!
  • sawyersawyer Frets: 732
    Good job! Looks cool:)
  • Hi @MattNovak, ;
    Only seeing this now! looks great! I need this back lol
    Michael
