Jazz Bass Frequency Chart?
thegummythegummy Frets: 4389
You know that when both pickups on a J are on full there are certain frequencies that get cancelled out and turning either pickup down even just a hair opens the sound up massively?
Has anyone seen such a thing as a frequency chart that show which frequencies get cancelled?
I guess it might be more complicated than a static EQ curve but there's a definite specific sound. I think I've tried, unsuccessfully, to find some info on this in the past but maybe someone here will have seen something.
  • fretmeisterfretmeister Frets: 24388
    Might be something on the EMG site - they have an "Active Balance Control" that is supposed to combat it. Sometimes they have freq graphs showing the benefits of things.
  • ICBMICBM Frets: 72427
    It's *far* more complicated than a static EQ curve - in fact it's not specific frequencies at all, it's different harmonics on the strings, which varies depending on which fret you're playing at.
    Basically, any harmonic where the string is moving upwards over one pickup and downwards over the other will be cancelled, and one where it's moving in the same direction reinforced.
    You can't reproduce it with EQ, but you could probably get close with a fixed phaser, or an 'enhancer' type effect which works by mixing out-of-phase harmonics with the main signal.
    So every note is affected differently then?
    Cool! Should have been obvious really!
    Yes - and even the same note played on different strings, since the string length relative to the pickup position and separation is different.
    That really makes so much sense, thanks for that.
    I feel that there is definitely a cut off in the high end as soon as both are up full, regardless what note I play - is that in my head or maybe just on my particular bass? Or is the high end always dulled and it's the mid range that gets the varied cancellations?
  • JezWyndJezWynd Frets: 6085
    I've noticed that as well. Turning either volume down a very small amount seems to fatten the sound and give back upper mids/high end. This on a 62 with vintage style passive pick ups.
    The high-end might be affected slightly more because as the harmonics get higher, the notches of the comb-filtering it produces get closer together, but where that runs out will depend on the particular strings - thicker and less flexible strings (including flatwounds) simply don't produce many high harmonics at all.
    I always hear it more as a loss of punch in the lower mids - the fundamentals aren't affected, but many of the harmonics that give the P-Bass it's midrange growl are, so the result is the classic smooth slightly scooped Jazz sound.
    Am I right in thinking that with both volumes maxed, there is a hum cancelling effect?
    Yes, because the pickups are RWRP.
    What hum?
    I've got EMGs in mine! :D
    What hum?
    The loud annoying hum! I've got nylon strings and Fender Original pu's, so no earthing even with hand on strings!
    edited April 2021
    That's buzz, not hum. It's a real problem with nylon tapewounds - the only real solutions are extremely thorough shielding, or EMGs.
    Surprisingly, old Höfners - the other bass most often fitted with nylon tapewounds - are actually pretty well-shielded and don't really have this problem.
  • jaymenonjaymenon Frets: 819
    This is interesting
  • FunkfingersFunkfingers Frets: 14472
    This is why the changed position of the long/bridge pickup during the CBS era altered the sound slightly. (I happen to prefer that sound.)
