veldt666 saidIf I were to spec my own custom amp it would be a 2 channel SC preamp(s) with valve rectifiers into dual power sections each feeding a 12" cone. Buffered effects loop, post eq preamp out and power amps in for stereo delay and modulation.
Maybe I need to give up the avocado toast for a while and start saving.
[This space for rent]
For a few years, I used my SC combo, as a pre amp, use the Line out, to a stereo processor, then, out, in Stereo, to a power amp, feeding, either, 2 X 1 X 12 Boogie cabs, or a stereo 4 X 12.
set the mix in the processor to 50/50, wet/ dry, & you will hear the true potential of the pre amp section. You still have the source sound coming from the 1 X 10 spkr, but compared to the processed sound, it's insignificant, in level.
Probably the best sound I had for years, I just got fed up, connecting it all up at every gig.
Give it a bash.
For what it's worth I fitted mine with effects loops - at the reverb mixer stage - and ran two in stereo with one preamp feeding both power amps via a Boss SE-70 in the loops. That needs an FX unit which will take line level though - without adding pad/re-amp circuitry the loop is then at too high a level for pedals.
I'm not going to compromise on something with a larger cabinet (which will mean a 12" speaker). I have two 5E3 based combo amps with 10" cones so have no real appetite for another small speaker combo.
Although in this case, I might leave it alone since it's probably more like the Super Champ as stock... crank the mids to get more gain.
Even in the UK they don't come up often and when they do, they tend to be well north of £600. I just happened to look on Ebay on Thursday and boom - there were two well under £600 and the other one was collection only. Funny how life works like that sometimes, same thing happened with a Wilkinson VS100CV trem recently - like unicorn poo over the last 10 years but I found one within seconds of looking last month. It wasn't cheap though.
£400 is a great price for a handwired classic from one of Fender's best eras of amps. I don't expect to lose money on it if I ever need to sell. It'll be a perfect compliment for the Burman Pro501 I also have.
An alternative that has been suggested to me is to use a preamp like a Mesa Boogie Studio to give it some extra kick.
If I were to consider a Rivera combo, I'd probably go for an M60 if I could find one. But a Trace Elliot Trident might be better value.
http://www.thefretboard.co.uk/discussion/106224/questions-fender-concert-ii-rivera-era-planning-mods-and-footswitches?new=1
Thanks in advance for any advice you can offer.
A couple of months ago I snagged a Champ II on ebay for a reasonable price. That amp has now been fully recapped and revalved (I added a bias trimmer too).
Then, this week, just like buses, along came a Super Champ, also on ebay. I put in a lowball offer expecting to negotiate a bit, but the offer was accepted and I'm expecting the amp in the next few days. It was described as "in need of refurbishment", but it looks to be all there, just dirty with tarnished hardware. I'll keep you posted.
Rob
@MCluer, as yours is stock, have you checked the current draw on the 6V6's in the absence of any bias trimmer? With my Champ II, all the pairs of 6V6's I tried were drawing 40+ma, so I had no choice but to increase the negative bias voltage.
Rob
https://www.ebay.co.uk/itm/260992711941?epid=695738106&hash=item3cc460bd05:g:XH8AAOSw46BdeqYS
However, there is a simple way of modding the amp so you don't need one at all... as stock, the reverb driver is a paralleled 12AT7 (standard for Fender) and the 6C10 is used for the reverb recovery, intermediate gain stage and phase inverter.
If you remove one half of the 12AT7 from the reverb driver (change the cathode resistor to 1.2K), you can then use the spare half for the reverb recovery, put an adaptor plate over the 6C10 socket hole and fit a 12AX7 for the intermediate stage and phase inverter. This does reduce the amount of reverb slightly, although not that much - but why they didn't design the amp like that in the first place rather than using an obscure valve type, I have no idea.
