Switch your guitar over so that you are playing left handed, now try bending vibrato with the wrong hand. You will get a result somewhat akin to my attempts! I really can't believe how bad I am.
He also suggested starting by just bending up to pitch for a while, to get the note in your ear, then try the vibrato bit.
One tip I'd suggest is to get the technique under your fingers with strings lighter than you normally use, then switch back to your preferred qauge. Once you hear it you've got it.
