Victory preamp pedal with Katana 50
alvynmcqalvynmcq Frets: 11
Anyone done this or anything similar with a valve preamp pedal, running it in to the power amp in on a katana 2?
Would it even be worthwhile? I was thinking of doing it to have a ‘tube’ sound as well as everything else the katana can do, without having to own tow separate amps
  • monquixotemonquixote Frets: 17622
    When I've tried preamps into the FX return of the Katana they don't sound Great
  • I've used a Victory Sheriff into a Katana with excellent results. Used as a 'big pedal' at first.
    My pal later reported the Sheriff also sounded superb connected via 4 wire once he'd sorted the levels.
    Katana sounded better in 50W mode than attenuated.
  • alvynmcqalvynmcq Frets: 11
    What is the Laney like precisionguided?
    Not sure what way to do this. Might put a post in the amp sales bit and see if anyone has a wee 1 or 5w head for sale
  • Laney's not bad for a pedal but nothing is as good as the Sheriff ch1  ;-)
    With single coils or humbuckers it's more open than any pedal.
