Hi All
There have been a number of discussions relating to the Pure Mini and LR Baggs Anthem, including when I was trying to decide which system to use in a Dreadnought Acoustic build.
The guitar was for a pro-musician I know, Matt Marriott (amongst many other things, he does some of the demo videos for Faith acoustics and Laney amps).
There is a build thread in the 'Making and Modding' section with all the details but, in summary, in the end I fitted BOTH the Pure Mini and the Anthem and each with its own jack output so he could choose which one, based on the venue, band/solo mix and sound system to use or even mix the two by using both feeds into separate amp or mixer desk channels.
And he's just done a couple of videos, first video using the Pure Mini and second video using the Anthem.
Now, it's not - this time round - an exact comparison. Yes - the sound system is identical and in both cases it is the direct feed from the relevant pickup and an additional external mic. But there is a difference because the first one is capo 5 and the 2nd one is no capo.
I will try to get him to do a more direct comparison sometime, but here are the two videos to be going on with.
By the way, he did comment that the Anthem was more tricky to set up because of its relatively low output, something he tells me is 'apparently well known in the business'. Sounds nice, though...
Pure Mini
https://youtu.be/8SCNbnmBY2Y Anthem
https://youtu.be/OFt0PxnpdTo These being hard times for musicians, I'm sure he would appreciate a 'Like' if you do
The K&K sounds much better to me there. It's far more natural and balanced - the Anthem has too much boom on the low-end, and still the distinctive tizzy piezo attack.
Would it be possible to ask him to record the exact same piece with the two outputs recorded separately at the same time? And preferably with no room mic, or as little as possible if it just sounds too dry without.
Yes - I will be asking him to do just that. It's the advantage of having the two output arrangement. One of the very few times where we can do a comparison where simply everything is equal other than the pickups themselves!
Thank you, these are the two pickups I'm considering for my D18
(but if you're in a rush and want a sneak preview, it's pretty much sure to be the K&K )
It might also help to include some plectrum style playing and a bit of vigorous strumming to hear how each pickup copes with the wider dynamic range.
Precisely why I ditched my Anthem SL and replaced it with the Lyric (Tru-Mic only) system.
Bandcamp
Spotify, Apple et al
