Or people who have very expensive jewellery but are too scared to wear it
There becomes little point owning it in the first place if it can't go out and do it's job
Having said that you wouldn't take it to a really rough shithole
However that is one reason I've never really been interested in vintage guitars which are worth much more financially than they're worth as guitars - it just compounds the risk for no good reason.
Although I have played a pub gig with a 50s Les Paul Junior - they were worth less in those days, but perhaps not that much less in real terms. I don't think doing it with a 50s Standard now would be a very good idea - it's unlikely it would be insurable.
If I'm recording, then I'll use the originals, as then I'm with them all the time.
Guitars should be played I think...... Tho I'd prob be more careful with a les Paul than a strat, as dropage would be more serious!
But then again i don't own a 59 les paul...
PA Hire and Event Management
I take the Starcaster out quite a bit as it's definitely in player's condition and it sounds incredible with those lovely old Wide Rangers in it. The Jaguar doesn't come out so often as it's a bit more of a minter, though I intend to take it out a bit more often once work starts again.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
The gigs I play, most punters wouldn't know if I had an Epiphone Les Paul or one of my 50's ones. Given that I will never be able to afford to replace one of the 50's ones, I'd rather take a replaceable instrument with me. It's also not the value of the guitars that stops me taking them. I do actually gig with my 66 Precision though, even though it's older. For some reason, I think I never actually think of it that way.
