T-Cut is fine - that's precisely what it's designed for.
what ever you choose don't use a cheap duster as they can scratch and leave swirl marks - Good micro fibre cloth required
There are a lot of waxes out there designed to fill swirl marks (tiny scratches) but this isnt a permanent solution, If it were mine , and it was all over the guitar, Id probably strip and use wet and dry then polish, but then again, Id probably just leave it scratchy if Im honest.
Used it on loads of guitars, poly and nitro. Takes away swirls and minor scratches.
I put some deep scratches in my MIJ tele and tried to polish them out, turned out the colour was sitting near the surface of the finish not under it and I took a patch out before I knew it.
I know it’s not the same guitar as yours but be careful is all.
