Digital Piano and USB Midi Controller
My son has been teaching himself to play piano on an old Yamaha keyboard we were given by a friend. He's now keen to do a bit of recording too.
So rather than just get a USB Midi Controller Keyboard I was wondering if there any digital pianos that can also act as USB controller on a budget?
Any recommendations would be much appreciated
  • jackiojackio Frets: 132
    Hi yes I’m sure there are. I’ll do my best to help buuut, what’s the budget ? Does it need to be new or will 2nd hand do? What will he be using it to control?
    Best wishes
    jack
  • oafoaf Frets: 300
    Roland FP-10 perhaps? A friend bought one for his (piano beginner) wife and she was very happy with it. I'm not sure that it has MIDI in/out so you'd be relying on USB only (check this if it matters to you, it would to me). The RD range might be a good buy used too.
  • MusicwolfMusicwolf Frets: 3672
    As jackio says many, if not most, will do this.  I bought myself a Casio CDP S100 at the back end of last year which was under £300.  MIDI I/O over USB (it doesn't have any old school 5 pin MIDI connections).  Works seamlessly with Cubase.
    I found that the step up from semi-weight keyboard to the Casio, which has a budget haammer action, really helped me.
  • WhistlerWhistler Frets: 322
    Just check that the one you buy has a MIDI out socket on the back, as that is what you need for a keyboard to be able to work as a MIDI controller. I think you will find that most keyboards made since the 1980s will have MIDI capability and a MIDI out socket.
  • Duppy03Duppy03 Frets: 104
    Thanks for the great responses so far.
    Budget is as cheap as possible, £150 and below (as that’s the price of the Casio CTS 300, which is a contender).
    Preferred connectivity would be USB direct to output.
    Not 100% sure which apps yet as still exploring options, but definitely Garaband for starters.
  • StratavariousStratavarious Frets: 3702
    edited April 2020
    Had it not got midi already? What model of Yamaha?
    It will look like one or two 5 pin DIN sockets marked in and out.
    you get plug and play midi > USB cables
  • sweepysweepy Frets: 4195
    You can pick up a USB Midi interface for @£7 on eBay
    Sorry that should have said "USB direct to laptop".
    The Yamaha he has is a really basic beginners model, PSR 77. The only connectivity it has is Power and Headphones/Line Out
    I've done a little more research and come up with these as contenders:
    Yamaha PSS-A50
    Fame G-400
    Casio CT-S200
    Yamaha NP-12 BK
    Any advice would be great thanks.
