The secret to a successful pinch harmonic every time?
zepp76zepp76 Frets: 2534
Is there a certain technique I should be practicing to get a successful pinch harmonic every time I try or is it a given that there is always a chance of failure? I’m starting to dread practicing songs with them in for fear of not being able to nail it every time.
Tomorrow will be a good day.
  • Phil_CPhil_C Frets: 261
    Pick close in towards your thumb/finger and pick downwards near vertically
    Works for me everytime :)
  • VibetronicVibetronic Frets: 1037
    I tell people to pick 'through' the strings instead of attempting it and raising the pick up and away from the strings after.
    Practise makes perfect. There was a period were I always pinched the last phrase on the break.
    I play bass these days, so not much call to do it. Well, none in fact.
  • GassageGassage Frets: 31030
    New strings.
  • robertyroberty Frets: 10912
    If anyone knows, it's @Vibetronic :-)
  • merlinmerlin Frets: 6801
    edited May 2020
    Remember it's a harmonic you're after, so the position of the pick needs to be in a good place to really ping. Try moving your hand towards the neck and towards the bridge and you'll see how the frequency of the squealer changes. "Longer" harmonics tend to jump out more and more gain and harmonic complexity in your sound will help too. Fuzz/dist/overdrive etc
  • LestratcasterLestratcaster Frets: 1105
    Sharp pick tip, loads of gain.
  • duotoneduotone Frets: 1005
    I find it works best for me if I turn the Mids right up.
  • axisusaxisus Frets: 28348
    They go well for me generally and I don't even use a pick
    It's like finding your way to Carnegie Hall
  • mudslide73mudslide73 Frets: 3106
    I wish I didn't do it so much. My guitar teacher told me to "leave a bit of thumb in there" and it worked straight away.
  • PolarityManPolarityMan Frets: 7310
    The position along the length that you pick the string is actually the largest factor, far more so than the actual pick / thumb technique.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • ColWilkieColWilkie Frets: 145
    Lot of good advice.  I get them both on the down pick with the thumb, and up with the second finger.
    I would agree with @PolarityMan that the position you play it is a major factor.  This actually changed it for me, as soon as I started shifting around I found where it worked.
    Also, I started off with minimal gain (counterintuitive I know!).  This meant that once I had them down, they sounded absolutely spot on with the gain added!
  • rossyamaharossyamaha Frets: 2462
    Mids
  • mrkbmrkb Frets: 6971
    They’ll also vary with the fret position (if it’s not an open string) as you are exciting a natural frequency of the string length.
    Karma......
    Ebay mark7777_1
  • Danny1969Danny1969 Frets: 10496
    Yeah this, plus where you do dictates if it's an octave or fifth etc. If you don't consider this then the results can be a bit random but you can choose what harmonic your gonna get by using the pickups as landmarks ..... essential on the top E and B strings where  pinch harmonics are generally hardrer to do.
    The type of guitar makes a different. A Les Paul fitted with EMG's is probably the easiest guitar even with only moderate gain.
  • DeeTeeDeeTee Frets: 764
    Ah, the Zakk Wylde formula.
  • zepp76zepp76 Frets: 2534
    The man who’s music has the most pinch harmonics in musical history!
     Thank you to you all for your advice.
  • I have no trouble with the technique as such but on some songs it’s hitting the node point on the string in the exact right place . I was playing the 18 & life solo by skid row for months but if I did not hit the string in that exact node point it was unsuccessful , I even tried drawing a line on my right hand to line up with a certain place on the bridge to get my hand in the right place so I would pick where the node was , plus I was using mega gain & a compressor to make them pop .
    a lot of places they pop out so easy
  • KebabkidKebabkid Frets: 3340
    And John Sykes, actually a bit too much when I saw him live with Thin Lizzy in the comeback stuff but he could hit a good 'un, as could Alex Lifeson and Billy Gibbons. They were the first guys I heard doing it but there are so many now.
