I suspect that a Rat into a Marshall amp should get you reasonably close but Pulp were definitely a "studio magic" band so I suspect it's many things all at once.
That said, if you're in the mood for buying pedals, @ThorpyFX 's Bunker is a Brown Source update and sounds like it would get you pretty damn close
What I could really do with is a short video of a fairly bland amp and many pedals played into it one after the other: this is a Rat, this is a Tubescreamer, this is a Guvnor... it seems such a useful idea that I'm sure someone must have done it!
FWIW this is the main reason I bought a Mustang GT40 amp. It has a large list of amps and pedals (although the non-fender ones have their names obfuscated it's easy to find out what they are actually emulating). With the app it's easy to mix and match elements to try and approximate classic sounds.
