WTB - Hollow/Semi Electric Guitar (Epi, Tokai, Greco, Burny, Edwards etc...)
I have an itch for another hollow/semi electric guitar. Must have a nice rounded C or soft V neck. Skinny and "Slim taper D" necks needs NOT apply...
Newer re-issues or older archtop blues machines. Budget is up to 600£ but could up it for something special
Interested to see what is out there...
£750
If it’s your thing, I have lots of pics, and I’m sure we could sort something out. I’m open to an offer around £425.
Good luck.
Pulled from the Ibanez wiki https://ibanez.fandom.com/wiki/List_of_neck_types
Neck type: AS
Years: 1997-2002
Scale length: 628mm/ 24¾"
Width at nut: 43mm
Width at last fret: 57mm
Thickness at 1st fret: 20mm
Thickness at 12th fret: 22mm
Radius: 305mmR/ 12"
Sorry if this a slim taper D. ¯\_(ツ)_/¯
Cheers
Jools
Got any pics @4on6 ?
https://www.thefretboard.co.uk/discussion/116465/edwards-335-made-in-japan-e-sa-125-lts-with-wolfetone-pafs-sold
As Benecol says in his profile, the neck is thicker than the slim taper. DOn't have the measurements of my old one to hand but certainly thicker than my Dot.
The current Hofner Verythins probably won't work for you as mine is 20.5mm and 22.4mm neck thickness at 1st and 12th frets respectively.
