Up to 60% is fine
Basically when it's cold and dry e.g. snowing, icy weather, and you have central heating on (or a roaring log burner), internal humidity can get to 30% or below. Under 30% is bad. During those times, throw a wet towel on a radiator, or use a humidifier. Having the window open on drier days can bring it down a lot.
I keep mine around 45%-50%
at 40% or 55% they need retuning, and the action changes a little
at 36% or 60%, you will notice the action change, and more retuning is needed
