If activating the push-pull switch noticeably changes the tone, it is either engaging a filter or, more likely, shunting some or all of the output of one coil to ground.
I strongly suspect that the stock Chapman control circuit involves simultaneous coil split of both humbuckers. Adding phase reversal would require an additional switch or push-pull pot.
I did some experiments on phase using a Fender Mustang, since it has the switches as stock - that showed no genuine difference, and it was inaudible if you weren't switching while playing, but those pickups are pure single coils with no baseplate.
I tend to put these sorts of differences at the level of "you can hear something change when you directly compare the two sounds together, but if you hear either of them in isolation you would not be able to tell which it was".
It is a bit OCD I know , but I do like to find out about this sort of thing - I've found some that don't matter when popular opinion says they should, and a few the other way round.
As an impressionable 18 year old and after reading Adrian Legg's book on customising your electric guitar I foolishly thought "I'll have some of that". I took my beautiful Fender Flame Master Series guitar to Andy's guitar workshop in Denmark Street to get some magical switching options installed. To say that it was butchered is an understatement (I'll post some pictures later if anyone is interested), and I only discovered quite a few years later when I took it to the excellent Martyn Booth that the numpty that worked on it originally hadn't even wired it up correctly!!
At the time I thought that a 3 way micro switch installed for each pickup giving series/ single coil/ parallel option, and a third switch which phase reversed one of the pickups would give me every sound that I could ever dream of!. The phase reversal switch has since been removed during the corrective works as I've been told that it is just too complicated to wire and retain the 3 options for each pickup. In reality, there is such a small difference between the single coil and parallel positions that in the future I might get it changed to a 2 way series/ parallel switch for each pickup and try to get the 3rd phase switch reinstated. But hey, you live and learn.
I used to do all this sort of stuff too, and you can end up with the control cavity looking like the inside of a BT street box if you're not careful .
Not a lot of things are completely beyond repair, but that’s pretty close. To make a clean job you’d basically have to re-top it.
I'm very tempted to get the phase reversal switch reinstated as in the original (incorrect) wiring I liked the tone option. I found a wiring circuit which looks hopeful albeit that there is an additional switch for neck+bridge series parallel!
https://guitarelectronics.com/2-humbuckers-3-way-lever-switch-2-volumes-2-tones-series-split-parallel-reverse-phase-master-series-parallel/
You could use the second half of that switch to fix the problem - you would break the connection between the bridge pickup volume control and the main selector switch, connect the top terminal on the switch to the bridge pickup volume pot, the middle terminal to the bridge pickup connections on the selector switch (ie two two connections you've just separated), and the bottom terminal to the neck pickup volume pot output.
