HX Stomp - Powering Through Ojai ?
  • LegionreturnsLegionreturns Frets: 7965
    Probably not helpful, but the Onespot pro DC7 powers a stomp fine, right out of the box, using the included cables.
  • sgosdensgosden Frets: 1994
    I've ordered a 2.5pin barrel off ebay to connect into the stomp,
    Plan is to cut off the end of two existing cables and solder them in parallel into the new end.
    Once it's all in I can confirm if 4x4 will do it :)
    Will be UnclePsychosis said:
    Sorry for the necro bump, anyone tried powering a stomp with a Voodoo Lab 4x4? Its on the "line6 list" so I assume its ok but would like some real world use cases.
    I have a current doubling cable somewhere so I assume I just need the adaptor linked above.
  • althyalthy Frets: 92
    sorry if that's a bit off topic but I am concerned about overheating the stomp by fixing a ojai/zuma/ cs6 underneath it.
    Is there a documented risk or has anyone here been doing that with no issue?
  • WazmeisterWazmeister Frets: 9610
    I’ve done it mate; no issue whatsoever
  • BeexterBeexter Frets: 616
    Same here
    4x4 happily powers stomp if you do it off two outlets @UnclePsychosis ;
  • UnclePsychosisUnclePsychosis Frets: 12951
    Nice one, thanks
    Nice one, thanks
    Didn't for about £3 in parts and 2 minutes soldering too :)
    Are you using two normal outlets or two high current ones?
