SOLD : Bogner Ecstasy 25 Head £980 ono
Possibly the most feature packed lunchbox amp ever made? Incredibly flexible with three channels, multiple modes from clean to classic crunch to full on high gain. The dynamic mode on the drive channel is awesome with pedals.
Also has a Foot switchable gain boost, FX loop (which a can also be used as a solo boost) and a bright switch for the clean channel. It has a recording out and speaker simulation with adjustable voicing - never used this.
The bottom line is if you want a Bogner Ecstasy that you can carry on the bus or tube to a small gig or recording session then this is for you. The sale includes a heavy duty padded carry case. Saves lugging a full sized Ecstasy around !
It’s in pretty much immaculate condition save for the missing black knob on the ‘Bite’ switch on the back - the switch works fine but the knob has dropped off somewhere.
The tubes are Sovtek EL84M’s and a mix of EH and Tung Sol preamp tubes - all selected because they sound awesome. Note that fitting new EL84 power tubes will need the amp bias to be checked - this is fixed and not cathode bias but there are internal test points to do this.
Selling as I have up an unnecessary number of amplifiers. Collection preferred but can post to the UK as cost and will be securely packaged.
Have a bump as it sounds amazing watching the vids!
