HELP! Spraying Nitro, weird streaks?!
This is only my 2nd nitro spraying project and I've had no issues with sanding sealer and white primer, however today I started spraying the Shoreline Gold and the fist light coat went on fine but the coats since have weird streaks in them, I have shaken the can plenty and am spraying horizontally to the guitar. Do I have a dodgy rattle can or am I messing up?
The images below are after the 4th coat
Any help/advice appreciated
https://i.imgur.com/SJF9k3h.jpg
https://i.imgur.com/3N9zaYG.jpg
Fretboard Feedback https://www.thefretboard.co.uk/discussion/58705/  ALSO Over 500+ 100% feedback eBay transactions
  • mrn1989mrn1989 Frets: 240
    FYI, all the products used are from Northwest Guitars, so no mixing of brands and all the Aerosols are Nitro based
  • John_PJohn_P Frets: 2750
    Looks like damp from moisture in the air to me.     I've had similar and it disappeared when it dried overnight so you might be ok tomorrow.
  • WezVWezV Frets: 16737
    Looks like lacquer bloom due to humidity.  Should go on the next coat, but you may need a drier day for the final ones.
    Try rubbing with a clean cloth an hour or so after spraying too... Sometimes that shifts it
  • FunkfingersFunkfingers Frets: 14511
    Looks like uneven distribution of the metallic pigment within the clear medium.
    How much time did you leave between coats? From what distance are you spraying?
  • poopotpoopot Frets: 9099
    What @WezV said... it’s lacquer bloom... too much moisture in the air trapped under the lacquer as it falls...
    had it before, this, believe it or not was a clear coat!...
    You can try gently wafting a hair dryer over it, should disappear quite quickly... you can also get rid of water marks from furniture with this method ;)
    Dont over cook it tho’
    So did the 1st coat this morning, left it 30 mins and did a 2nd then did another a couple hours after, thats when i started noticing streaks, then just did a coat an hour or so ago. Spraying distance is roughly 20 -30cms
    Just had a go but it didn't seem to do anything, does it haveto be done after a fresh coat?
  • hollywoodroxhollywoodrox Frets: 4191
    Humidity definitely, when I was once spraying a bass headstock building up layers of lacquer over a decal then sanding down, each time I checked humidity levels for my area on line , I also stored it in a dry boiler room indoors
    I did some searching and I've seen it could be due to it being sprayed to closely, they recommended spray from 2-3 feet away and it being something to do with the metallic flake laying flat cause streaks/patches, I'm assuming they spray has flakes?? Sorry I'm a total finishing noob
    Just looked it up, currently humidity is 90% in my area
    Facepalm Crowd GIF - Facepalm Crowd - Discover  Share GIFs
    So keyed the finish back and sprayed another coat the next days and all is now well, phew, thanks for the help guys!
    https://i.imgur.com/N8pCh01.jpg
