No-mid-hump overdrive?
kswilson89kswilson89 Frets: 222
What's everyone using for a medium gain overdrive without the TS style mid-hump? I'm looking for an overdrive to switch to when soloing but would like to avoid overdrives that give a BIG boost in the mid range as I think it changes the sound too much. I've been thinking of maybe the Xotic Soul Driven or a dumble in a box kind of pedal. Any suggestions would be greatly appreciated!
  • sweavesweave Frets: 65
    Might be worth trying a Thorpyfx Gunshot as it has 2 distinct gains - one with the mid hump and the other more mid scooped. By blending the two (and a separare tone control) you might be able to get what you are looking for.
  • ICBMICBM Frets: 72467
    Boss Blues Driver
  • handsomerikhandsomerik Frets: 1007
    Greer lightspeed
  • monquixotemonquixote Frets: 17645
    Liquid Sunshine.
  • fretmeisterfretmeister Frets: 24422
    Visual Sound / Truetone Open Road overdrive.
  • munckeemunckee Frets: 12400
    Nobels ODR1
  • PC_DavePC_Dave Frets: 3396
    Greer lightspeed
    ^^This
    Or a J Rockett GTO
    This week's procrastination forum might be moved to sometime next week.
  • richman6100richman6100 Frets: 339
    If you're using humbuckers, I'd also suggest the ThorpyFX Gunshot. Personally, I prefer the Warthog with single coils. Sure it can do RAT like distortion, but it does wonderful medium gain overdrive too. It's a cracking pedal and so versatile it's hard to define.
  • StratavariousStratavarious Frets: 3683
    i got a Boss OD3 exactly for this.
    OCD is a very good pedal too and goes from flat OD to full on distortion
  • ColsCols Frets: 7036
    Full size TC Spark.  Switchable between neutral, mid-hump and fat.
    I would say the OD-3 has a substantial mid hump, it's just less than a TS/SD-1.
  • prlgmnrprlgmnr Frets: 3991
    Full drive flat mids version?
    EHX Crayon?
  • menamestommenamestom Frets: 4722
    Timmy?
  • horseheadhorsehead Frets: 220
    GE7
  • stickyfiddlestickyfiddle Frets: 27126
    I always thought the Bluesbreaker circuit was the go-to "no mid hump" drive circuit, so that or any variant thereof.
  • GassageGassage Frets: 30929
    Guvnor, cos it has a 3 band EQ and you can dial the mids out.
  • robertyroberty Frets: 10893
    DOD 250, bloody lovely
  • Rowby1Rowby1 Frets: 1280
    JRAD Tim Pierce.
  • i got a Boss OD3 exactly for this.
    Having mostly used TS- and Rat- based pedals, I got one of these a few months ago and have been using it a lot for low-to-medium gain rock stuff, with MXR Super Badass for anything heavier.
    I wouldn’t say the OD-3 has flat mids, but I find it nicely balanced across the spectrum, with plenty of top end clarity and solid low end.
  • JHS Angry Charlie has 3 band EQ with cut/boost mid.
