If it's broken off that far down, heating may be difficult. If it's one of the corner ones I would go for drilling a few small holes alongside it on the sides that won't show, and force it over into them so you can grab it with pliers. You'll then have to plug the damage before you can get a new one in.
I would use Titebond (original). I would also score the sides of the plug before you fit it, to make sure the glue isn't either trapped under the plug which will prevent it going fully in, or completely forced out of the joint.
