Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
it will work if the pearl is very thin and i did have some logos made from abalone like this. They were so thin you didn't inlay, just sat them under the finish.
Instagram
Instagram
Instagram
I’ve try for some time to fined some one with a laser cutter to cut MOP for me, only to fined lasers will not cut MOP. If the MOP is 2mm thick the laser will not touch it or the MOP will be turned to dust as @WezV said.
Having gave up on lasers I found the best way to cut MOP is on a small CNC machine using mini diamond router bits. The CNC will also cut the pocket in the headstock or fingerboard as well so you get a perfect fit.
The CNC machines do not cost very much as little as £400 but for under a £1000 you can have a CNC that will cut say the inlays in a Les Paul fingerboard in one go, see the link below.
I would be doing this my self but I suffer from asthma so I can’t work with MOP.
http://www.ebay.co.uk/itm/NEW-6040-ROUTER-ENGRAVER-ENGRAVING-DRILLING-AND-MILLING-MACHINE-CNC-q5-/181222804702?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item2a31b88cde
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
