So the search for my first classical guitar in approx 40 years came to an abrupt halt yesterday - a bit sooner than expected. I yo-yo'd between buying a "proper" classical vs buying a hybrid/crossover. I'd started leaning towards a hybrid (for playability reasons).
However, yesterday, I found myself playing a new Cordoba C10 classical priced at the top of my planned budget and realising that this would be a fine guitar to take home. Then I asked to play the C12, somewhat well outside what I'd had in mind to pay, just to see what the extra dosh would bring to the party...
So, the pic below is of my new Cordoba C12. All solid woods. Cedar top, rosewood back and sides. Bone nut and saddle. Despite my search showing me I prefer the playability of crossover classicals, none of the crossovers I played sounded anywhere near as good as this. And in the end, it's the sound you make that counts, not how easy it was to produce that sound.
The guitar was made in China. Build quality looks and feels excellent. Lattice-braced (the C10 I liked was fan-braced). I'm going to sound like a cork-sniffing valve amp enthusiast now, but the tone is complex and rich compared to the C10 (which in itself I would have been very happy with - it's a good guitar) and I just had to have it. The fretboard is "raised" where it meets the body, so it's a bit easier to get your fingers onto the high frets. It responded to changes in right hand position and strike velocity in a pleasing way. I've got nails on my right hand at the moment, but I don't always. It'll be interesting to see how it sounds when the strings are struck with flesh.
So, apologies for the usual gushing thoughts of someone with a new guitar. Now I'm going to knuckle down and try and get some pieces under my fingers to justify buying the thing!
https://www.dropbox.com/s/jv1ebb0tnt324gi/IMG_2204.jpg?raw=1
Sometimes the right guitar takes you by surprise
If you haven't come across them before, I'd strongly recommend the Bridget Merkimedes books if you are looking for classical inspiration
You should post again soon and let us know how the journey goes.
John Williams only plays lattice-braced now AFAIK, and uses Carbons
Call the London guitar studio for advice if you want, they supply him
However, as I think I mentioned, they are very slippy, put on 3 times the number of twists at both ends as the normal clear strings.
FWIW, I played the C10 and C12 without knowing anything about how they were braced. I just went with my ears (and my wife ears at 5m away in the shop).
I went to buy a Ramirez 1A made by Amalia Ramirez, https://nugentguitars.com/amalia-ramirez/
and ended up with the Stephen Hill 1A instead
@ToneControl nice choice. I test played a Stephen Hill a few years ago before getting a Vicente Carrillo, and it was a lovely thing indeed. a 660mm scale neck IIRC.
This is the main reason it always is the best choice to go and play the guitars you want to buy. . The Cordoba MIC Luthier series are excellent, i think. I'd like to try and see what the Spanish made FCWE is like.
I had a GK Pro and found it the nicest Cordoba I've played (I thought better than the Fusion crossovers) - although I've never been able to try a C12 - they don't do a lefty version.
I wouldn't worry about a leftie C12. You've got a leftie Cary! :-)
As you say, it is all luthier stuff and at the end of the day it is down to how a particular guitar sounds, plays and feels - regardless of what is inside. I love the Cary but I can't help being curious ......
Still very happy and enjoying making nice noises. Like most "projecting" guitars, it sounds better to other people in the room than it does for the player - which is a real shame. I'm starting to see the value of ports in the upper bout.
Now thinking of changing the strings and doing some experimenting with materials and tension. After that (probably in the New Year when I can assume it's settled down nicely) I might see what a luthier can do to improve the playability further - but I want to be confident about the strings I'll be using first.
Yep, took a friend last time so I could listen to a variety of possibles. He didn't rate the C12 above other choices, but it was plain to me out front. The sound is just somehow much fuller and solid than the C9/10.
