Squier Jagmaster Pickguard Anyone ?
  • ICBMICBM Frets: 72574
    edited June 2014
    DrBob said:
    Right, so on my Strat it's 174-5mm from centre of the screws-centre of the 22nd fret.
    On the Jagmaster it looks more like 172mm from bridge screw hole centre to rearmost point of neck pocket.
    Close enough or doomed ?
    Close enough! There should be at least 3mm of adjustment in the bridge saddles. More importantly, it means it's not a 24"-scale body since the difference would be greater - you can't get a Strat neck even close to intonating on a Jaguar body for example, it's a full two frets out. (A Strat neck would need 23 frets to intonate correctly on a Jaguar.)
  • DrBobDrBob Frets: 3006
    Hurrah ! Thanks man
