Bill Laswell's Gear
Bass• 1977 Fender Precision with a modified fretless neck and Leo Quan Badass bridge
Amps
• Ampeg SVT-CL heads
• Ampeg SVT-VR heads
• Ampeg SVT-810E cabs
• Ampeg SVT-215E cabs
Effects
Not sure but I found the above.• Aguilar DB 900 Tube Direct Box
• Boss DD-3 Digital Delay
• Boss DD-7 Digital Delay
• DigiTech Bass Synth Wah
• DigiTech Whammy II
• DigiTech EX-7 Expression Factory
• DOD 545 Wah Filter
• Dunlop 105Q Cry Baby Bass Wah
• EBS UniChorus analog bass chorus
• Electro-Harmonix Bass Big Muff Pi
• Ernie Ball 6166 Mono Volume Pedal for passive electronics
• Moogerfooger MF-102 Ring Modulator
• Pigtronix EP2 Envelope Phaser
However I am damn sure the Source Audio Spectrum Intelligent Filter will get so close you won't tell the difference.
I've been listening to a bunch of Aswad stuff and they were a lot more experimental than I would have imagined ( although no stranger to the cheesy cover version as well).
Cheers
That's too old a recording to have anything like that on it though - it's a modern digital pedal, not really a modded envelope filter, although it can do that type of sound. It actually just sounds like an envelope filter to me, possibly with compression which tends to make it sound more like that.
I've had success with my Zoom B1xON. Cheap as chips but the synth sounds are good, as are the amp models and fx and the synth tracking is decent.
If you can find one, they're not to expensive and come up used for between £30-40.
It's just amazing.
I eventually remembered the Laswell track, this is from 1984 and it's pretty similar - I probably haven't heard it for ten years so remarkably similar for my brain to go oh doesn't that sound like that although this may be more obviously envelope filter:
Cheers all
