Would you modify to fit, or replace.
Assumed replacement P Bass tuners from Schaller would fit my GSP basses P Bass I'm going to put together, but turns out I was wrong (I measured the peg holes etc..)
I could modify the top to clear the headstock, but would you just scrap that and order a different set?
  • WezVWezV Frets: 16782
    I think I would go for a different set, just for the aesthetics.  Functionally, it will work fine with 3 screws
  • It should not be difficult to sell or swap your Schallers for something of equal quality with a smaller baseplate.
    What is the diameter of the pre-drilled ‘head post hole? How far is it in from the upper edge of the headstock? Is your project instrument left- or right-handed?
  • poopotpoopot Frets: 9099
    They should be a standard PBass fit...
    here’s the fender version:
  • PVO_DavePVO_Dave Frets: 2379
    Just ordered a set of smaller footprint Schallers, more in the style of the ones on my Stingray from Thomann, so should get them this week I guess.
    True and this one is going to look special too with the paint, I can't imagine my dremel work would improve that :D
    Expect a for sale thread imminently!
    It's a right handed P Bass, no ruler or tape measure to hand at the mo. The tuner holes from the face are 17mm, can't remember the diameter from underneath
  • martmart Frets: 5205
    That definitely looks like the hole is not in a standard place, so you may have to look hard to find pegs that fit.
  • The Schaller BM “Stingray” type has a shorter stem length, this brings the flat key button nearer the edge of the headstock.
    It should be possible to dismantle both sets of Schallers to construct a working hybrid.
    the holes should be 7/8th inch from the flat part of the headstock to the center of the hole... or 22.2 mm.
    Approx 17mm diameter on top and 14mm from the back...
  • GSPBASSESGSPBASSES Frets: 2351
    If I remember correctly that neck should take Schaller BM “Stingray” type. You could send the neck back to me and I’ll replace it with a vintage style PBass neck that will take the bigger back plates.
  • Straight from the horse’s mouth. :)
    Guess what? I have a box of Schaller BM ‘heads that I would have happily traded for the Kluson-alikes. Feck! Arse! Knickers!
    Thanks all.
    @GSPBASSES - Not to worry, the replacements are on the way.
    That is a shame @Funkfingers - but if you need a new and unused set of the bigger Schallers, you know where I am :)
    Thats better :)
  • The combination of scaled down headstock and tuners works well. Almost like a Mustang Bass.
