Followed closely by Boss OD3, Marshall Guvnor and Boss BD2.
In hindsight I could have saved thousands!
In my case the Boss OD2 I've been using for over 30 years.
I realise owning a pedal for longer than a fortnight is an alien concept for many of you on here.
TS
OD-1X
MXR Super Badass Distortion
I'm sure there's much better pedals out there than the 2 I've got but to find better becomes a bit of a crusade, like most of the stuff we buy. I'm also into hi fi. Most hobbies are reasonably cheap once you've got over the initial outlay for your gear to get you going. Unfortunately guitars and hi-fi aren't, or at least tend not to be. Should have taken up birdspotting. Binoculars, bird book, butties and flask,
Ian
Tubescreamer type (with either hard or soft clipping)
RAT Style
Bluebreaker Style
Klon Style
Even then they can be boiled down to Soft Clipping (in the feed back loop) or hard clipping (to ground), with or without a mid hump and with or without lots of head room.
