HX Stomp plus HX Effects or Helix LT?
Current setup is HX Stomp controlled by a Morningstar MC6. Nice & compact, powered by usb powerbank, but the limited number of blocks is a little annoying at times..
Where to go next?
Add a HX Effects unit to the existing setup - how do the Stomp & Effects “play” together?
Ditch the lot and get a Helix LT?
Anyone use the stomp & effects together?
  • UnclePsychosisUnclePsychosis Frets: 12923
    edited September 2020
    Given the combined price of each I think you'd have to have a really niche use case to justify having separate units over an LT, even just to save on cables and power supply hassles.
  • Given the combined price of each I think you'd have to have a really niche use case to justify having separate units over an LT, even just to save on cables and power supply hassles.
    It’s only really a question as I’ve already got a Stomp, so c£400 for effects or c£800 for LT.
  • Yeah but if you sold your stomp you'd probably get £300-and-a-bit quid for it. And judging by eBay you can get an LT for £600-and-a-bit these days.
    I just don't see the point in having two units when you could combine into one. I guess there's a slight argument about reliability if one breaks but convenience would trump that for me.
  • BeexterBeexter Frets: 599
    Where to go next?
    I have done - see this thread
    https://www.thefretboard.co.uk/discussion/190274/hx-effects-into-stomp-and-amp-patches#latest
    Also, the next firmware update is rumoured to increase the number of blocks you can have in the Stomp...
  • I've been trying it (as per Beexter's post) and it works pretty well.
    Main advantage over the LT is that you get the scrobble strips on the HX effects.
    Plus I can use 2 footswitches on the stomp for amps and one for turning reverb on or off.
    Other advantages are you have a backup solution for the HX if it fails, and size wise it's still smaller than the LT.
    I am tempted to try a preamp n the loop of the HX and use IR'ss from the HX.  That might work well.
  • Gone for a LT to keep things all in one unit.
    Should be here Monday.
  • duotoneduotone Frets: 987
    You won’t be disappointed.
  • guitarcookie1guitarcookie1 Frets: 464
    I’m not, it’s here early..
    Brilliant news.
    Have a great Sunday playing! How are you getting along with it?
    I’ve found the Austin Clean & Austin Lead to be my favourites of the presets.
