Post-Lockdown pedal building
  • Late to the thread, but I built 5 pedals so far since lockdown with a couple more on order. Found FuzzDog to be great, easily the best kits in terms of ease of build, good mods where needed, and good support, although you pay a bit of a premium. Musikding is a bit cheaper, and can be good if you want to order other random bits to customise your pedal. Due to their instructions being a bit ambiguous, I had some issues with polarity on LEDs and input jacks but was easy enough to fault find and resolve. Haven't tried Jeds but his inventory looks almost identical to FuzzDog, and something about the branding puts me off.
    Also some other random stuff I've 'discovered'. You can sign up for an account with Texas Instruments and order some free samples of different components. I've got a couple of gucci op-amps coming to 'upgrade' my builds with lower noise components (who knows if this will make an audible difference).
    Finally, if anyone is interested in the Fairfield Circuitry style of enclosure finishes, order a 2mm metal punch alphabet set off Amazon for a tenner and one of these conveniently sized aluminium blocks off ebay to use as an anvil:
    https://www.ebay.co.uk/itm/ALUMINIUM-BAR-BILLET-BLOCK-45mm-x-80mm-x-50mm-GRADE-6082-T6/264298769749?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    You can then colour in the lettering with black enamel paint, ink or marker pen and wipe/sand off the top.
    It's a very cheap way of achieving a nice pedal finish without spending a lot of time and money on primer and enamel paints. The LEDs they use can also be ordered from Musikding, they're called fresnel lenses.
    Some great tips here. Will look at musikding. I have somehow just not spent a lot of time on that site, considering I look at most of the building sites a lot.
    At the moment I am trying to do more with Vero and learning to breadboard. But I do like to build the kits as well.
    Jed's is very good for the newbie, the support forum on Facebook is just fantastic.
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • slowpilgrimslowpilgrim Frets: 134
    edited October 2020
    Does anyone have any tips on upping the quality of your builds? I’ve built a few pedals now and basically improvise a workflow each time. Then I see this level of rigour for wiring etc and I get jealous, it really is an art form:
    https://www.pinterest.com/amp/pin/596515913128831821/
    (The image)
    After you’ve populated the PCB, do you do all your PCB wiring and do a mock-up in the enclosure to cut to length for jacks, switches etc? Then remove and solder everything outside before final assembly?
    Also, for soldering I’m always hit and miss when it comes to getting a nice connection with a minimum of solder and a shiny joint. Sometimes my iron (a Chinese Amazon job) struggles to get a nice flow. Is it worth upgrading to a proper station, or a higher quality pencil iron?
  • rsvmarkrsvmark Frets: 1384
    @SteveF Finally the printers have come back to me.... £68 plus vat for 1 off UV print!!! Errrr no thanks. As a matter of interest, how much did you pay and how did you source them?
    An official Foo liked guitarist since 2024
  • robertyroberty Frets: 10893
    edited November 2020
    (The image)
    I'm nowhere near as tidy as those examples but my method is to solder the wires to the main PCB and jacks first, mount everything in the case and then solder the wires into the daughterboard. Then the daughterboard gets soldered to the switch. I solder the DC wires to the daughterboard first and then put them through the hole and solder the DC jack outside the case. This is probably as tidy as I've been. The trick is to make the wires the right length which I find really difficult for some reason
  • KeefyKeefy Frets: 2302
    (The image)
    That's pretty tidy, I'd be more than happy with that!
    Thanks for the tips, my last builds were a lot neater by assembling, cutting wires to length and then removing and soldering outside of the enclosure.
    Here's how the letter punch turned out:
    https://live.staticflickr.com/65535/50554403342_159bdb8ba4_h.jpg
    These are for sale on the classifieds if anyone is interested, along with some builds I did earlier in lockdown, to fund more kits:
    https://i.imgur.com/QExTsos.jpg
    Kind cool, but for my next build I'd like to try some interesting paint finishes. Has anyone experimented with nitro paint like the early BJFE pedals? Always thought that aesthetic was great.
    Love the graphics and colours. I can't draw to save my life. These look fantastic
  • SteveFSteveF Frets: 539
    Hi @rsvmark - I had mine done at Tayda.  I paid around $10 for the powder coated and printed enclosure.  I am going to use the drilling service as well next time to save time on the build process as I am building a batch. I think this adds another $2-3 to the cost of the enclosure.   I believe they discount if you order more than 5 or 10 too.
    They have some really specific instructions and requirements for the artwork, but it's not too difficult to set up.
  • @stevef that sounds really good. I’d happily pay that sort of cash for a decent powder coated & drilled box
    Thanks... ah well, not suited to this build. Enclosure is already drilled and powder coated. Yellow pages time....
  • LastMantraLastMantra Frets: 3825
    https://drive.google.com/file/d/1XP4cR4sH2-IzN5mK9jA-cxVnxd-PzO2K/view?usp=drivesdk
    Crap!
    Edit; Can anyone see that pic?
    I've just used a stamp for the lettering but got my dad to bead-blast it which I think looks quite good. I gave it a clear coat too to keep it fresh looking.
    It's a RM type germanium boost.
    Thanks, sold the Dunes clone (Crunch) to someone on here but kind of regret it now!
  • markblackmarkblack Frets: 1591
    Anyone built a good spluttery, nasty fuzz kit they recommend? Fancy building another fuzz, but not the usual muff clone type thing.
    Cheers
    Mark
    Cheers
    Mark
    It’s technically a Rat plus octave, but the FuzzDog Death Drive (Sunn Life clone) does a fantastic spluttery/nasty fuzz “thing”. It’s quite delicious.
    I'd like to try some nice hammered finishes for my next pedals. I remember reading something about these great results Basic Audio have had, where there's great 'veining' and depth to the colour:
    http://www.mrdwab.com/john/temp/Blue-boards.jpg
    http://www.mrdwab.com/john/Goldie-web.jpg
    https://2.bp.blogspot.com/-eZpAf95d6F4/WaL7EoCySiI/AAAAAAAAEbA/bkVF05oe20oysCI2gdJFtcbDPVBt_qYWwCLcBGAs/s1600/Wildcat.jpg
    There's a tutorial that's similar here:
    https://pedalprojects.blogspot.com/2013/12/spray-painting-metal-enclosures-hammer.html
    But this shows a single flat colour. Does anyone know how to achieve the above results? I'm sure I read a while back that the trick is to spray one hammered colour, then layer it with another over the top. But looking around it seems much more likely to just be these special 'burnished' rust-oleum colours like:
    https://i.pinimg.com/originals/85/e8/aa/85e8aa78821b62dd0e414316080a7575.jpg
    Not available in the UK .
    EDIT: further resources for cool hammered effects:
    Swirling
    https://retrofokus.blogspot.com/2014/09/fuzz-and-hammerite-match-made-in-heaven.html
    Maybe the key is just spraying it on really thick to get more texture:
    https://hotbottles.wordpress.com/2011/03/15/ts-overdrive-new-enclosure-sound-samples/
    Going to order some and experiment.
    @stickyfiddle cheers i'll check it out
  • I'd like to try some nice hammered finishes for my next pedals. I remember reading something about these great results Basic Audio have had, where there's great 'veining' and depth to the colour:
    Swirling
    Apparently adding silicon gives more texture, which is likely what the forged stuff has. I'm going to try spraying the pedal with silicon oil before use the rustoleum.
    Swirling
    I've tried with various colours of Hammerite spray and never got them to look like this  :/
    Cheers
    Mark
    Fuzzdog Supreme Being (Dwarfcraft Shiva/She Fuzz). Love mine
