Withdrawn: MacBook Pro 15” 2017 - 3.1GHz i7 - 16GB RAM - Radeon 560 4GB - 1TB SSD - Space Grey
octatonicoctatonic Frets: 33801
edited November 2020 in Studio & Rec £
MacBook Pro 15" 2017 for sale.
High spec: 3.1ghz i7, 16GB RAM, 1TB SSD.
This was fully refurbished by Apple under warranty at the start of the year.
I took it in for a warranty repair as the battery didn't hold charge.
When they pulled it apart they noticed a couple of things needed doing, the battery had swelled a bit, the screen was part of a recall.
When they started the repair they also noticed a fault with the logic board too so that means it has had a new display, top case, keyboard, battery, IO boards, logic board (with soldered on RAM and SSD).
This means the only thing I got back from Apple that I gave them was the bottom case, which doesn't have a mark on it as I keep it in a protective case, which you re welcome to.
Original box.
Original power supply.
AppleCare runs through until January 21 2021.
£1200. No trades thanks.
