Lidl sell both types and you must get the right strings or it will either sound terrible (nylon on a steel-string guitar) or cause serious damage (steel on a nylon string guitar). From the size - if that's 41" - I think it's a steel string, but do check!
If it's nylon, any standard set of normal tension strings, or hard tension if you prefer. If it's steel, any standard set of 12s - or 11s if you're a beginner and need something softer on your fingers - will do fine. You don't need to spend a lot, and in fact on a fairly cheap guitar you won't get any real benefit from more expensive ones.
Hope that helps!
It has steel strings,
I'll go with 11s,
Thanks again
I wouldn’t put 10s let alone 11s on it.
I work part-time for a mail-order company that sells this sort of thing, they're more robust than you would think. The problems with them which we see are to do with the quality of the fretting, the nut and bridge saddle, and the machineheads.
