Rick 11 string in the skip
TeyeplayerTeyeplayer Frets: 3223
edited January 2021 in Guitar
Flippant fret title aside, I’ve spent the last 3 hours messing with my 360 12 string (by which I mean, new strings and a new tailpiece. Attempt at a new nut, but decided to leave to the experts).
Now I love this guitar, but man do I hate it too.
Anyone fancy a new rockery or something (Ric based)?
  • ICBMICBM Frets: 72471
    Send it to me - I will dispose of it responsibly for you, free of charge.
  • TeyeplayerTeyeplayer Frets: 3223
    edited January 2021
    I bloody bet you will, if only you were nearer! You’re a tech I need on my doorstep.
    My mates got a Ric 12 string. He was showing me the bridge, and how fiddly restringing was. Life’s too short for that nonsense..
  • Kent747Kent747 Frets: 261
    I’ll gladly trade you a Squier Mini Stratocaster in pink. No worries about the strings - it won’t stay in tune anyway.
    edited January 2021
    Well it’s done now. Just need to set it up later on and then I can sit back and enjoy the glory of its jangle for 6months.
    Edit: keep an eye out for a FS thread next restring. ;)
  • impmannimpmann Frets: 12668
    A tip... Elixrs.
    Rick 12s are horrible to restring, so to minimise the number times you need to do it, use Elixrs.
    Or sell it and buy a Shergold 12... much easier to string, tune and play. Does it sound the same? Not identical but it’s a great sound. That’s what I did!!
    impmann said:
    A tip... Elixrs.
    You and Mike Rutherford :).
    I have to admit that Rick 12s aren’t the easiest to restring, even for me having plenty of practice - I think owners often pay for them to be set up purely to avoid it... they’re not that hard really, but there is a method to it which you need to learn to make things easier, and you do need a proper work space where you can lay the guitar down flat.
    I would never use Elixirs though... they might last a long time but it would take away any desire to play it ;). You need the proper Rickenbacker rolled-wound strings - they really do sound better than anything else on them, and they’re also quite long-lasting.
    Mr Rutherford was right!!
    I quite like Elixrs. But each to their own.
    Thanks gents, I’ll try both at some point although won’t be any time soon. :)
  • Let’s be honest, even restringing a Ric 6 sucks a dick. A 12 looks horrific.
  • Restringing a Ric isn’t really that hard, I’m puzzled as why it’s seen as a thing - My technique - put a gentle 30 degree or so bend at the ball end of the string just where the winds on the ball end finish up.
    Slide the string under the R far enough to clear it, then pull it forward so the ball catches in the wee hooks. Pull the string straight and clamp in place with a capo.
    If you have a 12 and the right angled tuners, chop the string somewhere close beyond the next tuner, put a 90 degree bend in the string and feed it where it needs to go. Wind until tuned. Then repeat upto 11 more times.
    Easy.
    From another thread.... this is what I do.
    Easy.
    I don’t find it particularly hard to be honest, just fiddly and slow going. Admittedly, Friday night beers don’t help accelerate the process.
    I’ve gone over to trapeze tailpieces on both the 6 and 12, makes life much easier.
    The way they look bothers me. Restrung my 330 last week and got away with it, relatively speaking... but it’s a task less appealing than guiding ones father into ones mother as a general rule.
    Winfield Vintage trapeze for the win.
    The R tailpiece is generally pretty shoddy, I had one literally tear apart, went through a load of faff to get a replacement (I had to send in my broken one and a friend in the US had to buy it for me and post it over) and the finishing on the underside was so rough, like if it was on a sub-200 quid instrument you would accept but not on a tailpiece that cost half that.
    I moved over to trapeze and never looked back
    I quite like the trapeze look tbh:
    https://www.flickr.com/gp/157224850@N02/62b3aS
  • Just to be different, I actually like the “R” tailpiece - I know the older ones can be weak (mine broke), the quality is indifferent at best and they are a little fiddly.
    But to me it finishes the guitar. If you like the trapeze though go for it.
  • FunkfingersFunkfingers Frets: 14491
    This.
    You and Pete Townshend! He was emphatic about the importance of the proper strings when his signature model was issued.
    The other essential ingredient is two Teletronix LA-2A compressors, connected in series.
  • MikeSMikeS Frets: 2133
    edited January 2021
    I also cannot be faffed with changing my "R" Tailpiece 12 string, and have it strung as a 6 string using the stock 12 string Nut. Although this means the top E string sits a bit away from the edge of the fingerboard, I quite enjoy playing like this (and I've got tree trunk fingers).
    I enjoy playing it as a 12-string with 8 gauge, but find 10's too much tension. Haven't tried 9's.
    I currently have one of those Winfield 12-string Harp Tailpieces on the way from the States, which should make changing strings a breeze, but I can see myself still stringing it with only 6 strings. I just seem to prefer playing my Ricky 12 string with 6 strings.
    I do prefer the look of the R tailpiece, and I don't like the sharp 'claws' on the trapeze, but I have to admit the R is more of a faff to re-string - and I've come across a few broken ones.
