Carr Mercury V for home use
  • russpmrusspm Frets: 445
    I believe the Ironman 2 mini does has a 1/4” line out. I’ve never used one so can’t comment on how well the unit performs. It’s much cheaper than the PS2 but doesn’t have as much functionality. Let us know how you get on mate.
  • Benm39Benm39 Frets: 718
    I've a Mini Ironman 2 and can confirm it has a 1/4" line out.  Although it doesn't have the same smooth sweep of attenuation that the PS2  does,  the combination of the multiple  attenuation steps with Hi/Lo ranges, the presence cut of 0db, -3db  -6db and the solo boost do mean it's pretty flexible even at quite heavy attenuation levels.
    That solo boost function sounds very handy
    Yup, basically a foot stomp to add c 6db if i recall correctly.
  • eoinzyeoinzy Frets: 128
    edited July 2022
