Can we have a Delete All button in Drafts?
Please.
  • Emp_FabEmp_Fab Frets: 24429
    Also, and I've moaned about this before - change the interval between auto-saves of drafts.  Having it save every minute is ridiculous and also means that any posts you start but change your mind about posting, end up as another draft.
  • VimFuegoVimFuego Frets: 15619
    both good ideas, I seem to have accrued 77 drafts from somewhere.
  • axisusaxisus Frets: 28341
    I try not to look at the amount of drafts I have accrued. It can be scary.
  • EricTheWearyEricTheWeary Frets: 16299
    based on a previous Discussion I may well have a record number of drafts, I certainly have a lot of them. And they will stay there for ever I guess unless there is a delete all button. If they just timed out that would be okay ( or if they do time out eventually that just makes the number I do have even worse!).
    Amateur hour Vim! When you get to 1255 that's properly indecisive.
