And small footprint too. Maybe give it a look.
I'd echo the recommendation for the XR18. It's one of the most useful things I own. It works as a USB interface for multitrack recording, and is capable enough as a mixer to use for most small gigs.
If you're looking to make recordings (and especially if your son wants to mic up his drums and record) those smaller mixers will become limiting very quickly.
The main Q: how do you plan to record the drums? The guys above are suggesting that you need perhaps 6 mics for the drum kit alone.
If I was buying again id def spring the extra for the XR18 to get multitrack recording and more aux's
