Solo of the Month (SotM) #68 - Challenge
  • Does anyone want to provide a backing track for next month. Otherwise I'm going to use my previous RotM entry (link below) without the pinched harmonic part - now there's a threat.
    https://thefretboard.co.uk/discussion/201929/rotm-62-the-winner-is#latest
    Sounds good to me, reverend!
  • fastonebazfastonebaz Frets: 4109
    We haven't had a drill/rap/Drumgask style before.   Wonder if that's a viable  episode :hushed:
    BTW I can't stand those styles lol
  • joeWjoeW Frets: 463
    That gets my vote - sounds tasty
    Turn your monitors off, bung some headphones on and experiment with the mic position: head towards the centre where there's more brightness. I've never used a e906...if you're just dangling it, that may reduce options for playing with how 'on-axis' the mic is. Any other mics you could try?
    I haven't mic'd up for ages, but, from memory, I was always slightly angled and pointing close to the edge of the dust cap (using a 57 or a 421).
    n.b. I'm assuming that there's nothing else in the signal path that's getting in the way!
    Its just hanging, so it flat to the cones - I'll try adjusting the angles, thanks @digitalkettle ;
  • HabaneroHabanero Frets: 252
    So I searched for Drumgask to find out what is, and all I found was it's a town in Scotland?
  • stratman3142stratman3142 Frets: 2198
    joeW said:
    I could use some advise recording my solos as things seem to get too muddy.  I ran a Benedetto with a bit of compression and shimmer into a clean 633 grooveking (max headroom and -ve feedback, so Fender like).  E906 halfway between centre and edge of a 12".  This into Focusrite 2i2 and using GarageBand as its less fuss than Logic.
    The amped sound in the room has a lot more note definition even with flat wounds, so something is going amiss on the capture.  No surprise as I have little experience.
    I'm not sure there are any right answers because it's a matter of personal taste.
    You've got some good gear. The sound is warm and jazzy. The sound is up front but, in this track, it's a little dry for my taste and might benefit from some reverb. I used Valhalla Room.
     I sometimes do some post recording processing to help things sit with the backing (i.e. clear but not too loud). Sometimes that's tweaking an ampsim (which I didn't use on this case). And/or sometimes it's other effects in my DAW..
    In my case, I use Reaper and often try some presets with the stock EQ (i.e. ReaEQ), to get me close, then I tweak things a bit. I expect other DAWs will have something similar. Often I start with a ReaEQ preset called "stock - Mud Free" but in this case I tweaked a preset called "stock - Close Mic Acoustic. Both presets roll off the low end.
    I've very recently started using iZotope Neutron 3 as well, which I'm still learning and might use in preference to ReaEQ in future. Neutron 3 has some good presets and an AI mode, which is useful for hacks like me who are just tweaking presets by ear until it sounds nice.
    It's not a competition.
  • @joeW I'm no recording expert either, far from. I like the tone you have, but understand how you say it is somewhat muffled. I like when an archtop sounds maintains an acoustic ring to it.
    Perhaps you could do another recording, completely dry, no compression or reverb. See if you retrieve the definition in your recording that you hear live. And than perhaps balance the two recordings to your liking. Add some verb afterwards if necessary. But my personal experience is that you tend to lose definition when using reverb.
    Haha doh. Drumgask was meant to be drum n bass.
  • imalrightjackimalrightjack Frets: 3762
    edited March 2021
    I've not done this for absolutely ages.  I was sat around mindlessly noodling tonight, as often is the case totally bereft of inspiration.  I had a quick listen to this and decided to have a go, as the progression is totally out of my comfort zone.  It's somewhat constructed and I had to work on note choices, much as I like to just fanny on in one mode most of the time.  I'm not sure it fits brilliantly but hey ho.
    Recorded via Kemper into Logic, using a Friedman Brown Eye tone with a newly-acquired Patrick Eggle 96.
    Trading feedback info here
    My band, Red For Dissent
  • Sent one in!
    I've not done this for absolutely ages...
    Welcome back. It's in the playlist.
    Sent one in!
    That makes 12 in the playlist.
  • I've not done this for absolutely ages...
    Cheers! Had a listen back and it could have done with tidying up a few bends here and there. In terms of approach, I thought of the Gm and Am as part of F major, although I’m not sure I stuck to that. Quite a lot of trial and error, also much like @poopot using Logic and comping to then try and work out what to play in one take, which required a couple of punch-ins because I’m very much all about doing things like this in one sitting.
    I really like some of the acoustic tones others have used, and think they’re in many ways more ways apt than what I’ve done, but I was enjoying the tone I already had dialled in and stuck with it.
    I definitely want a Drumgask backing next  =)
    Would you be up for a heavy backing track?
    edited March 2021
    ...Would you be up for a heavy backing track?
    I was going to go with my entry to last month's RotM (link below). But I'm up for a heavy backing track if you want to provide one. Or maybe you could provide an example because I had a go at a 'heavy' backing track once and got the comment that it wasn't proper heavy metal
  • ...Would you be up for a heavy backing track?
    Haha, I'll send you one, whether it qualifies as proper heavy metal I'm not sure!
    That works too - feel free to bank whatever I send.  I'm sure I can give you a few.
    It used to be easy to classify in the 80s!
    I'm up for this...maybe over a 'post noodle core' backing track?
    OK, next month is a heavy metal backing track provided by @imalrightjack ;
  • OK, next month is a heavy metal backing track provided by @imalrightjack ;
    Yay :)
    Hopefully get a few entries.  If it's a tumbleweed moment, my profuse apologies in advance!
  • Assuming we're talking hair metal, which knowing @imalrightjack we are, I could be tempted. I know nothing about theory though so it will just be mindless noodling with as many tapping runs and pinch harmonics as I can muster.
    Haha, that’s not fair! Motley Crue = hair metal to me. I’d put it in the camp of modern Megadeth or Metallica. E pentatonic minor and you’re flying \m/
