What finish for Bocote?
I'm nearing the finishing stage of my first home build - body will be painted with nitrocellulose and the mahogany neck grain filled and finished with nitrocellulose lacquer.  I've put a bocote veneer on the headstock and was wondering whether it would take a grain fill and lacquer or, being a bit of an oily wood, it may be better just to fine sand, mask it off when spraying the rest of the neck and then give it a good polish with something instead?
  • WezVWezV Frets: 16734
    I would worry about lacquer adhesion, you would certainly want to remove the oil as much as possible first.
    Last time I used it was on a multilam neck.   I didn't de-oil it before glue up, just freshly planed wood.   It fell apart cleanly at the joins  as soon as I started carving.
        I'm now nervous about bocote :D
    I think leaving it raw and oiling after is likely safest
  • Opted to mask it off whilst I'm spraying everything else.  Think I'll experiment with some wax on some offcuts and see how it works out
  • peanutspeanuts Frets: 179
    any pics of the bocote? the grain character is often so good would be a shame to lose it behind a coat of something!
  • CheesyfeetCheesyfeet Frets: 16
    edited April 2021
    Ah, yes, meant to post an update.  Ended up sanding to 400 grit and then using Hampshire Sheen Gloss Finishing Wax (about a dozen 'coats').  I like how it's come out
    Need to sort the screws on the truss rod cover - countersink is blunter than a Piers Morgan interview
