Pack the filler into the pores using an old credit card in the direction of the grain and scrape off across the grain. It's best to use a rough cloth such as Hessian to remove the excess filler.
Also you won't be able to scrape properly where there is filler on the surface.
This time use a piece of hessian to clean the surface thoroughly. It's better to have to repeat the application than sand filler off.
