A Boss PSA230 should work as it's specifically designed for pedals, hence is filtered - I sometimes use one with my Behringer Superfuzz pedals and it's silent. Other cheaper ones may do the same job, but I would make sure it's a proper musical instrument company product and not just something generic from Amazon or wherever.
You can get deep into power supplies, but the bottom line is that if it works it's almost certainly fine...
The Boss one is even worse, about £25. Likewise 1-Spot and Godlyke Power-All.
The problem is that unless you're willing to just accept paying that much, you have to take pot luck with a cheaper one, and we're back where we started...
