Noise floor on pedalboard
CirrusCirrus Frets: 8494
What do you accept? I don't generally think about it, hiss is part of the instrument - especially with higher gain pedals and even moreso if stacking things.
But I noticed that if I use a buffer or other unity-gain pedal in front of my Rat clone, the background hiss is a lot higher - even though with the Rat bypassed I can't discern (or measure through my soundcard) any difference in the noise floor whether or not the buffer is in the circuit in front of the Rat - so I don't think it's as simple as the buffer having a higher noise floor for the rat to amplify. What else might be going on?
  • As I'm sure you know, buffers reduce capacitance in a circuit, allowing higher frequencies to pass more easily. Perhaps you can just hear more of the RAT's inherent circuit noise with a buffer in line?
  • WazmeisterWazmeister Frets: 9572
    I accept zero noise from an added pedal.
  • springheadspringhead Frets: 1597
    Buffers don't reduce capacitance, that's always there.  They reduce the effect of that capacitance and other loading impacts downstream of them on what is upstream of them.  If that makes sense!
    Is it just guitar > buffer > RAT >amp/soundcard ?
